14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Can't cut a section
0 Posts No Rating |
I am in a plan and attempt tp cut a section. I get this message
"None of the created elements are visible in Floor Plan: FLOOR PLAN View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
what do I need to do I am in version 17 - Thanks Byron
It means that something is stopping the sections from being seen. First check your VG settings to see if they are switched off. If not, check the scale of the sections - they have a parameter to make them not show at certain scales. Then check if there is a view filter that is hiding them. Theses are the first things to check for.
I don't understand... you title this as a section cut but you talk about floor plan. Is this a section or is it a plan detail?
0 Posts No Rating |
I have the solution from the first response - Thank you
Tough one - Phased site topography and visibility in section |
Thu, Jun 9, 2011 at 11:58:34 PM
Cut Pattern in Plan vs Section |
Tue, Aug 25, 2009 at 8:47:59 AM
Sections cut on mulitple sheets |
Fri, Jun 27, 2008 at 12:33:38 PM
When I cut a section or elevation in revit, it shows what's behind the cut plane |
Fri, Dec 6, 2013 at 12:47:17 PM
Is it possible to not have the bold section cut lines |
Thu, Apr 3, 2008 at 12:58:16 PM
