Forums >> Revit Building >> Technical Support >> Wall Thickness in Type Parameter
Thu, May 31, 2018 at 5:09:01 AM | Wall Thickness in Type Parameter
Bogumil
I created the lintel in Door Family section above the door. It will add another lintel (110mm) if the "Wall Thickness" increasted to 220mm. I would want it assigned the "Wall Thickness" in Type Parameter to (Wall/Edit Type/Structural/Thickness) default. When I changed the dimension of the wall thickness under (Wall/Edit Type/Structural/Thickness), it will pop up "Error"
How to make the Wall Thickness under (Wall/Edit Type/Structural/Thickness) become to be master and Wall Thickness in Type Parameter become to be slave.
For example, the picture of Type Parameter below: I hope it will clear up to you.
Thank you for your assistant.
Fri, Jun 1, 2018 at 1:07:22 AM | Wall Thickness in Type Parameter
tim123
4 Stars: 19 Votes
A door family is meant to fit into whatever wall you host it to, so you don't control the wall width from the family.
Fri, Jun 1, 2018 at 2:15:01 AM | Wall Thickness in Type Parameter
Bogumil
Yes, I mean that I wanted having a lintel adding if the wall thickness increased by wall control in the project. I just want to know how it assigns to wall thickness default. So the Lintel can work out the divided by wall thickness.
Fri, Jun 1, 2018 at 4:16:11 AM | Wall Thickness in Type Parameter
Bogumil
I discovered that Wall Thickness is not one problem but it is Lintel Spacing linked to Lintel Width in the formula of the parameters which it causes the problem when I changed the Wall Thickness. The Lintel Spacing is one very imoportant to stay array together in order. Do you know how to solve this problem issue?
Edited on: Fri, Jun 1, 2018 at 4:23:28 AM
Fri, Jun 1, 2018 at 7:28:06 AM | Wall Thickness in Type Parameter
tim123
4 Stars: 19 Votes
Well you want Revit to determine the amount of lintels based on the thickness of the wall, so this is the variable parameter.  Try  a formula for Number of lintels, which is the integer value of wall thickness / lintel width.  Then create an array using the Number of lintels as the controling parameter for the number in the array.
Fri, Jun 1, 2018 at 7:39:15 AM | Wall Thickness in Type Parameter
Bogumil
That is what I mean, that is right. The amount of Lintel based on the thickness wall. I have tried it but still got error message :-/ if you have time to try it on your side, please can you share your file with me? That would be kindly appreciated.My file is here, you can have a look through it. My version on 2016.
Regards,
Bogumil
Door Family - wall thickness parameter!!
Thu, May 14, 2009 at 10:19:48 AM
parametric window should recognize wall type!
Wed, Apr 12, 2006 at 7:44:20 AM
adjustable profile family
Fri, Jul 20, 2012 at 9:08:25 AM
Getting Floor thickness in to shared parameter
Tue, Jun 19, 2012 at 7:30:19 AM
Panels of curtain wall with the same type have different thicknesses
Wed, Jan 4, 2017 at 11:30:34 AM
Page generation time: 2.1833
