Forums >> Revit Building >> Technical Support >> revit 2018 manipulate the title block or sheet
Wed, May 30, 2018 at 12:26:59 PM | revit 2018 manipulate the title block or sheet
joeinck
using templates is most helpful, but is there a way to apply this to sheets/title blocks?
for example we have two different title blocks, one for planning documents and one for construction documents.  as we know we can not have one view on two sheets.  we can control the displayed content of a view using templates but can we control the display of a sheets title block in a like manner?
thanks
james
Wed, May 30, 2018 at 2:11:37 PM | revit 2018 manipulate the title block or sheet
I think this may be your solution.
With both titleblocks loaded into the project, right click on the one titleblock that is currently in use and switch them all t0o the other titleblock.
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Revit Sheet Schedule/Title Block Family Tie In
Mon, Jun 23, 2014 at 9:47:21 AM
Title Block Labels
Wed, Feb 14, 2007 at 11:52:49 AM
In the default Revit Templates i couldnt find revit title block
Fri, May 23, 2014 at 7:22:23 AM
Page generation time: 1.9847
