Forums >> Revit Structure >> Technical Support >> Custom project parameters on title block
Mon, May 21, 2018 at 5:13:27 AM | Custom project parameters on title block
CADBucks
Morning everyone,
Firstly apologies if this is clearly explained elsewhere, I just didn't really know what to search for and my results didn't give me any help.
I'm starting to set up our companies first Revit title block and I'm at the stage where I'm adding labels for all the editable sheet information.
We have a situation where occasionally we are issued with a project number that the whole design team must use which will differ from our office internal project number so therefore we have 2 project number fields on our sheets.
I've added a project parameter for an "Internal project number" now I'm stuck as to how I get a label on a sheet to display that info? much like the OOTB project number label does.
I don't want it editable on each instance of the sheet as it's the same on all of them, if that makes sense?
Unfortunately I'm a complete Revit amateur so apologies if this is gibberish and I'd appreciate any answers in simple terms!  Transitioning from AutoCAD to Revit has been a complete struggle for me!
Cheers.
Mon, May 21, 2018 at 7:55:27 AM | Custom project parameters on title block
There are many helps on titleblocks here and elsewhere.
For your needs, you need a shared parameter that you load into your titleblock family and that you load into your project template under 'project parameters'.  Then using that template, you can assign your number and if you have done your titleblock family correctly, it will show up there.
So, research the HELP for 'SHARED PARAMETER' and Title blocks as well as some youtube videos.
Great to learn .... learning will help you with many other problems.
Title block labels not appearing in projct
Thu, Aug 22, 2013 at 5:36:25 PM
project title block
Tue, Dec 1, 2009 at 2:18:45 PM
Custom title blocks
Mon, Mar 24, 2008 at 2:00:44 PM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
How do I create Labels in the Title Block Editor?
Thu, Nov 13, 2008 at 9:28:46 AM
Page generation time: 0.6930
