Forums >> Community >> The Studio >> Which version to choose
Wed, May 16, 2018 at 8:27:47 AM | Which version to choose
Enlighton
Hello. Due to some reasons I've decided to Chief Architect to Revit. But I'm completely confused with different versions of Revit... My job is to redesign customer's houses. What I do is 3d scan building upload 3d scan to the software (It was Chief Architect and it will be Revit), Then based on this data make a new design for the building. As I know Revit has strong analitical instruments for physical characteristics of the building so I can calculate what to change and what not. Which Revit version will be the best choice for my workflow? To make 3d scans I use Artec Studio with Artec scanners (I provide the links so you can read how it export data).
Wed, May 16, 2018 at 11:00:44 AM | Which version to choose
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Use the latest version of REVIT. Either 2018 or 2019.
Mon, May 28, 2018 at 2:44:53 AM | Which version to choose
Enlighton
Thank you.
Tue, Jun 5, 2018 at 10:14:16 AM | Which version to choose
blue442
blue442 Avatar
Revit is updated yearly now.  Once you upgrade your model/project to a new version, the file cannot be downgraded to an older version.  This is important to understand.  Once you upgrade - YOU CAN NOT GO BACK.
Deciding on which version is an important decision you should make with your consultants involved.  If there are no consultants - then I always use the most current version of Revit, which is currently 2019.
Edited on: Tue, Jun 5, 2018 at 10:15:17 AM
revit latest version cannot be save to a lower version
Wed, Apr 27, 2011 at 10:00:25 AM
Insert Revit plan into Word
Mon, Sep 18, 2006 at 8:33:46 AM
Can't choose generic walls
Mon, Nov 7, 2011 at 2:59:18 PM
File in Student Version transfers to Professional Version
Mon, Jul 26, 2010 at 12:06:11 PM
Problem opening "component" version 9.1 in revit version 9.1
Fri, Jun 15, 2007 at 8:25:21 AM
Page generation time: 2.7259
