Forums >> Revit Building >> Technical Support >> Text Styles
Wed, May 31, 2006 at 3:16:56 PM | Text Styles
mattchu
I am creating a new title block and am trying to match an existing AUTOCAD title block.I am having problems getting the text to be as thick as it appears in AUTOCAD. Is there a way to adjust this in Revit or import it from AUTOCAD so it matches?
Wed, May 31, 2006 at 3:45:16 PM | RE: Text Styles
quiller
quiller Avatar
2.5 Stars: 3 Votes
When the title sheet is open in edit mode click on the lable you want to change. Go to its properties and if you want to change all lable that are this type continue to step 2, if not click edit/new and duplicate, call it something else and then, step 2 - click edit and under Text, click Text Font and in the drop down choose the font you want. Click ok and ok and you'll be all set
Removing Text Styles
Mon, Sep 19, 2011 at 12:17:03 PM
Text Styles
Tue, Aug 4, 2009 at 9:59:13 AM
Text Formatting
Thu, Oct 25, 2007 at 11:12:29 AM
deleteing text styles
Fri, Feb 13, 2004 at 2:12:32 PM
Loading hatches and text styles into title block family
Wed, Jan 4, 2012 at 11:50:49 AM
Page generation time: 4.1704
