Forums >> Revit Building >> Technical Support >> Vertical Mullion not centered in model but centered in family
Thu, Apr 26, 2018 at 9:52:05 AM | Vertical Mullion not centered in model but centered in family
benlink
Revit 2018.
There has to be something simple that I'm missing.  See the attached image.  I have a vertical mullion built as clearly and simply as I can.  There are a few parameters I will probably never need, but they're not in the direction of the problem. The mullion is centered and EQed in the family.  When I place it in the model, it goes off center by 11/32".  If I remove the EQ and off center the mullion in the family 11/32" it aligns with the curtain grid in the family.
I can use the work around, but would feel better if I knew the problem.  Thoughts?
Thanks.
.blc
EDIT: I've added a screen shot of the type properties.
Edited on: Thu, Apr 26, 2018 at 9:58:36 AM
Edited on: Thu, Apr 26, 2018 at 9:59:39 AM
Edited on: Thu, Apr 26, 2018 at 10:00:15 AM
Thu, Apr 26, 2018 at 6:34:04 PM | Vertical Mullion not centered in model but centered in family
Look at your mullion type properties - width on each side.
Fri, Apr 27, 2018 at 8:51:19 AM | Vertical Mullion not centered in model but centered in family
benlink
Thanks for the follow up.  I tried to upload an image of the properties, but it kept deleting the image of the mullion.  See attached.
Maybe I need to add an offset to control it, but I would think that as it's set up, it would center automatically.
Fri, Apr 27, 2018 at 9:00:50 AM | Vertical Mullion not centered in model but centered in family
benlink
And, see attached for the properties in the model.
Window Family - Keeping an Arrow Symbol Centered within a Glass Panel
Fri, Nov 18, 2011 at 1:20:30 AM
do columns have to be centered?
Fri, Mar 2, 2007 at 7:14:16 AM
Centered cut pattern in wall
Thu, May 29, 2008 at 10:25:54 AM
Windows Centered to Core
Thu, Dec 7, 2006 at 9:53:26 PM
Yes/No Parameters
Wed, Sep 25, 2013 at 2:19:56 AM
Page generation time: 1.9212
