Forums >> Revit Building >> Technical Support >> Revit 2018 Exterior Elevations
Thu, Apr 19, 2018 at 11:03:19 AM | Revit 2018 Exterior Elevations
byrdman91554
4.5 Stars: 5 Votes
in order to see the roof ridge lines, i have to extend the vie range of the elevaiton quite a bit.
when i do that, the elevation picks up everything inside the building, and on the opposite side of the building.
so i've been selecting items and hiding in view by element.
some floors i want to see, others i don't.
wome windows i want to see, others i don't.
so the elevations are acting like sections.
any recommendations?
thanks!
robert byrd
revit noob.
Thu, Apr 19, 2018 at 6:19:34 PM | Revit 2018 Exterior Elevations
I don't undestand why you say the elevation acts like a section - no way it can really do that unless your elevation cut line goes through the building.
We always modeled with the exterior walls, windows, doors and roof in a workset called shell.  By ony having that workset on, we did not have to hide interior items.  We did oly pull the view range as deep as required to show what would be see in that view but not the opposide side.
Fri, Apr 20, 2018 at 9:16:38 AM | Revit 2018 Exterior Elevations
readyroth
3.5 Stars: 2 Votes
Isn't an elevation really a section that is cut outside of the building?  Everything in the model that is within the view range will show up in that view.  As WWHub said, you can use worksets to control elements and more quickly hide those in views like this.  View template could do some of that as well if things can be hidden by category.  But if you want to selectively hide some elements (i.e. windows) but still see others, you're probably gonna have to manually do that per view.
Tue, Apr 24, 2018 at 9:33:00 AM | Revit 2018 Exterior Elevations
byrdman91554
4.5 Stars: 5 Votes
thanks for the help guys!
robert byrd
Tue, Apr 24, 2018 at 9:35:45 AM | Revit 2018 Exterior Elevations
byrdman91554
4.5 Stars: 5 Votes
WWHub:
would you mind giving me direcitons on how to set up the Workset Shell?
i've never used work sets.
and...thank you!
Robert Byrd
Tue, Apr 24, 2018 at 1:01:20 PM | Revit 2018 Exterior Elevations
blue442
blue442 Avatar
In the spirit of WWhub...
Check out this Help topic
Shadows on Glass in Exterior Elevations
Thu, Mar 27, 2014 at 7:44:04 PM
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:07 PM
Copying elements from old project to a new one in Revit 2018
Wed, Apr 11, 2018 at 3:32:49 PM
transparency on exterior elevations
Mon, May 21, 2007 at 5:51:15 PM
Placing building elevations
Mon, Jan 30, 2012 at 7:32:27 PM
Page generation time: 1.5591
