Forums >> Revit Structure >> Technical Support >> need to make a tubular steel framed structure
Thu, Apr 12, 2018 at 8:58:47 PM | need to make a tubular steel framed structure
Madmachinist
Making a carolina carport type building this involves 12 ga sq Tubular steel  I need to draw the members but am not having any luck.  Can anyone help.  for starters it looks like my sq tubular members are round?  Then I also need to make 2" square parts that nest inside for connectors.  Does thsi already exist somewhere?  Playted with revit a little last year and It seems like I am back to square one.
Fri, Apr 13, 2018 at 10:13:30 AM | need to make a tubular steel framed structure
You will find the square tube members in your structural library.
Do you really need to model the connectors?  I would not.
Horizontal Tubular Structure with floor
Wed, Aug 16, 2017 at 2:19:20 PM
Hip roof framed details - Revit Arch. 2013
Fri, Feb 15, 2013 at 6:27:06 AM
Steel Structure
Fri, Mar 11, 2005 at 1:39:35 PM
REVIT Structure and Architecture for wood framed buildings
Thu, Apr 18, 2019 at 2:38:02 PM
Wall Structure
Mon, May 11, 2009 at 2:10:04 PM
Page generation time: 0.5207
