29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Tag two same wall assemblies - one with sweep, one without
5 Posts No Rating |
I have two same wall assemblies in a project. Both walls have same construction but one is with a sweep on the top of the wall, while another doesn't. Since they are same construction, I would like to tag them same. That cause duplicated type marks.
I want to have the sweep withn the wall assmbly because it will be always there even i make some changes to the wall, otherwise, the sweep is very easy to be deleted when you make some changes.
A few of duplicated type marks might not be a big deal but creae a few more warnings. Is there a better way to deal with this situation?
Thanks for read and response,
Is this what your asking about?
Tag crown molding (wall sweeps) |
Thu, Mar 26, 2015 at 8:38:34 AM
Wall sweep won't trim |
Tue, Apr 25, 2017 at 2:07:17 PM
copying assemblies between projects |
Fri, Jun 1, 2012 at 10:39:32 AM
Graphic display options assemblies |
Thu, Nov 21, 2024 at 3:35:02 PM
Rooms as assemblies |
Tue, Apr 4, 2017 at 6:44:30 AM
