Forums >> Revit Building >> Technical Support >> why my projection lines overlap cut lines.
Mon, Apr 9, 2018 at 2:42:48 PM | why my projection lines overlap cut lines.
brankulo
in my building sections i have cut lines set as #4 black lines. projections lines for windows walls etc are set to #1 light grey. there are areas where projection line of the wall would overlap cut line. this makes cut lines apear thinner as they are partially obscured by grey projection line. not sure whay this is happening as projection items are further beyond and section is not cutthing through them. is there any way to control this? this only happens once printed to pdf, it looks all fine on screen.
thanks
Edited on: Mon, Apr 9, 2018 at 2:44:42 PM
Edited on: Mon, Apr 9, 2018 at 2:51:56 PM
Tue, Apr 10, 2018 at 1:03:44 AM | why my projection lines overlap cut lines.
tim123
4 Stars: 19 Votes
It is probably your PDF converter.  Try switching off 'Use Hardware Acceleration' under Graphics in your options if you have not done this.  Alternatively, try another PDF printer.
Tue, Apr 10, 2018 at 7:41:07 PM | why my projection lines overlap cut lines.
brankulo
So far the only thing that worked is raster instead of vector printing, which obviously sucks.
projection vs. cut lines
Mon, Oct 31, 2005 at 2:29:38 PM
Toggle cut and projection lines
Tue, Mar 6, 2012 at 6:57:56 AM
Visibility Projection and Cut lines.
Wed, Nov 5, 2014 at 1:55:03 PM
Projection Lines - Too Many Lines With Curves
Tue, Jun 3, 2008 at 7:32:05 AM
Walls' projection lines - how to turn them off?
Wed, Jun 26, 2013 at 4:00:09 PM
Page generation time: 2.0675
