Forums >> General Discussion >> Revit ROI >> How to achieve smooth edges?
Fri, Apr 6, 2018 at 2:17:13 AM | How to achieve smooth edges?
wayne783
Hi All,
Please see attached, screenshot relating to the following issue.
I have imported a 3D structure originally generated in AutoCAD, into my Revit model. However, both when in AutoCAD and in Revit, the curved structure i segmented. I am assuming this is not a Revit issue as it is segmented in AutoCAD before importing into Revit - Does anyone have any idea/advice as to how I can get this structure to achieve smooth curves rather than segmented angular lines as seen in the screenshot.
Thank you in advance.
Wayne
Fri, Apr 6, 2018 at 3:32:45 AM | How to achieve smooth edges?
4 Stars: 205 Votes
Create that directly in Revit and not Autocad and you'll not have that problem.
Smooth edges?
Sun, Jan 23, 2005 at 7:09:01 PM
Curved Stair - Smooth Underside
Thu, May 3, 2007 at 9:54:55 AM
shading with edges problem
Wed, Nov 17, 2010 at 6:49:49 AM
creating a chamfer on edges of an extrusion
Tue, Apr 21, 2009 at 5:47:05 PM
edges color and linetype
Thu, Apr 21, 2005 at 10:07:34 AM
Page generation time: 1.2494
