Forums >> Revit Structure >> Technical Support >> stacked structural concrete columns
Tue, Apr 3, 2018 at 5:32:34 PM | stacked structural concrete columns
selectstructural
How do I create a stacked concrete column where the column size/shape changes at each floor as it goes up the building?
I have been placing a new column at each floor but the boss wants it to be one column with one tag.
Thank you
Jennifer
Jennifer Arnold
jennifer@selectstructural.com
Wed, Apr 4, 2018 at 9:37:57 AM | stacked structural concrete columns
sllana
5 Stars: 2 Votes
what i would do is to group them and turn each stack in a single object, so if you move one in a level, all other segments in the other levels, also move. And use multi cathegory tag to give it a name.
Wed, Apr 4, 2018 at 9:49:51 AM | stacked structural concrete columns
selectstructural
yes i have done that before but it made a mess when they started changes sizes and shapes on me.  also i believe it splits the grouped column up in the graphical column schedule.
Thank you!!
Jennifer Arnold
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
Concrete columns behaviour before and after placing concrete beams
Tue, Apr 1, 2014 at 1:58:43 AM
Beams won't intersect or close-up to Structural Columns. Solution ?
Tue, Oct 18, 2016 at 2:01:11 PM
Cut Pattern - Timber Columns in plan views to black ?
Tue, Mar 18, 2014 at 7:41:46 PM
How do I apply plaster to structural Concrete Columns
Tue, Mar 4, 2014 at 1:09:38 PM
Page generation time: 3.8052
