22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Revit 2018.2 Print to PDF Turning Curves into Polygons
I use Bluebeam 2017 but I have tried a number of exporters including the DWF export. When I open the file, my curves have all been turned into polygons.
What am I doing wrong?
I have played with the settings extensively and can only put it down to bad vector plotting from Revit.
I could be wrong, but in my opinion you are still much better off printing shaded views to raster.
I hope someone has a better solution that elegantly plots shaded views in vector format.
Revit will automatically print shaded views in raster format.... after all, there are no lines in shaded areas.
I have semi-transparent trees over floors with a shade and a surface pattern. When visual style is set to 'consistent colours', everything prints as a vector - just a very bad one.
I just wanted to post an update that Revit 2019 is significantly better at this process. I still get some polygons but semi-transparent materials overlayed are showing really well as vectors.
Physical Print Quality of PDF's Produced from Revit |
Tue, Apr 23, 2013 at 9:49:54 AM
I want to print the whole document to pdf In one step |
Wed, Dec 8, 2004 at 7:23:00 AM
Wall Solid Fill Cut Pattern Jagged on PDF |
Fri, Apr 3, 2015 at 10:36:32 AM
Font will not print to pdf file. |
Wed, Aug 19, 2020 at 9:16:23 AM
Print to PDF crashing |
Tue, Apr 6, 2010 at 3:55:55 PM
