Forums >> Revit Systems >> Technical Support >> Shared Parameters in Wire Type family
Mon, Mar 26, 2018 at 3:44:16 PM | Shared Parameters in Wire Type family
Trygk
I've added a shared parameter to a wire type family called "Conduit Run Name" for tagging and scheduling home runs in Revit, and I've checked the "Electrical Circuits" category in the Parameter Properties.The tagging works fine, but in an Electrical Circuits schedule, the header appears but the field is blank. Anyone got any idea why, and how to overcome this rather frustrating problem?
Tue, Mar 27, 2018 at 9:09:34 AM | Shared Parameters in Wire Type family
When you have more than one value for a field in Revit, the field remains blank.  Look at your schedule sorting.  If your schedule is sorted by this field with show every instance, you will find the error.
Wed, Mar 28, 2018 at 12:56:44 PM | Shared Parameters in Wire Type family
Trygk
Yeah. i've only got the one instance, but thanks for your reply, I really appreciate it. Turns out on escalation that it's a "known issue." Anyway, I hope your post helps someone else. -tk
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
Problems with Shared Parameters
Sat, Dec 8, 2018 at 8:14:13 AM
Project Shared Parameters or Shared Parameters in Families
Fri, Feb 21, 2014 at 10:22:42 AM
Family type name as shared parameter?
Mon, Oct 10, 2011 at 8:28:04 AM
Yet another Shared Parameter Question
Tue, Sep 22, 2009 at 2:39:07 PM
Page generation time: 2.0150
