Forums >> Revit Structure >> Technical Support >> Room Tags
Sat, Mar 24, 2018 at 10:50:22 AM | Room Tags
UrbanDesign69
I was making a simple project so I can introduce Revit to others.  I tried tagging a couple of adjacent rooms and one was recognized.  The other said it wasn't enclosed.  What am I overlooking? (Revit 2017)
Sat, Mar 24, 2018 at 1:17:14 PM | Room Tags
  1. A wall may not reach the level the room is on.
  2. A wall may not be set to room bounding
Sat, Mar 24, 2018 at 1:40:29 PM | Room Tags
UrbanDesign69
I selected a wall and right clicked select all instances... all are from 1st floor to top plate and are room bounding.  Attaching to the roof shouldn't make a difference, should it?  I drew 4 new walls and those are recognized as a room when I tag.  Just can't figure out this situation.
Sat, Mar 24, 2018 at 4:30:30 PM | Room Tags
But you didn't say that all of the walls around this room have room bounding turned on.
Sun, Mar 25, 2018 at 1:56:25 AM | Room Tags
UrbanDesign69
Still don'thave an answer.  I'm going to be introducing Revit to an AutoCad based firm that does Affordable Hoin a couplr of weeks.   I don't want to get stuck on something this basic.  I'd really appreciate any additional help.  Is there another reason that the room tag may not recognize a enclosed room bounding space as a room?
Sun, Mar 25, 2018 at 1:57:45 AM | Room Tags
UrbanDesign69
ummm..... Affordable Housing in a couple of weeks.
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:12 PM
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Vanishing room tags
Tue, Sep 6, 2005 at 5:54:21 PM
Page generation time: 0.5546
