Forums >> Revit Building >> Technical Support >> window inset parameter for the Revit 2017 OOTB windows
Wed, Mar 21, 2018 at 5:07:48 PM | window inset parameter for the Revit 2017 OOTB windows
ledgewood33
i have noticed that the OOTB windows have a parameter that lets you position the window within the wall. i have been trying to replicate this parameter but having some difficulty. the OOTB window parameter moves the glass extrusion & mullions along with the window frame when you change the parameter. when i try this on my own window family i cannot get the glass extrusion & mullions to move with the frame. wondering how revit built this parameter?
Thu, Mar 22, 2018 at 8:55:22 AM | window inset parameter for the Revit 2017 OOTB windows
With items like windows, I start with a workplane that is well off of the inside face of the wall and I add a constraing, instance based dimension from the exterior wall face to that work plane.  Now I bulid those moveable items around this workplane.   Occassionally, I test the window by changing that dimension to verify moving function.  Before saving, I set that dimension to a reasonable starting one.
window with inset parameter
Thu, Jan 23, 2014 at 9:41:01 AM
Wall Type with inset coursing (Revit 2017)
Tue, Aug 15, 2017 at 10:02:46 AM
Embedded Windows
Wed, Jan 4, 2006 at 5:05:37 PM
Revit 2017 Text Displaying Differently - Windows 7 & 10
Wed, May 17, 2017 at 8:22:58 AM
window not cutting joined roof
Mon, Mar 6, 2017 at 4:23:50 PM
Page generation time: 2.1425
