Forums >> Revit Structure >> Technical Support >> Level Dimensions - Need Help
Fri, Mar 9, 2018 at 8:52:37 AM | Level Dimensions - Need Help
Cadman5540
Hello,
I'm new to Revit have a few questions.....
While making changes for the client (on the elevation pages)  I copied the Elevation Markers.   Now my Elevations Dimensions are off.
Please see attached file.   Is there a way I can manually change the dimension text without changing the walls/and linked items?
Thanks!
Fri, Mar 9, 2018 at 1:35:18 PM | Level Dimensions - Need Help
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You coppied what ? The levels ? If so you need to 'STOP' immediately and learn how to use REVIT  . . . OMG . . . STOP NOW !!
Close the file, do not save, take your hand off the mouse, step back and take some REVIT lessons.
Edited on: Fri, Mar 9, 2018 at 1:37:31 PM
Edited on: Fri, Mar 9, 2018 at 1:41:38 PM
Fri, Mar 9, 2018 at 8:33:25 PM | Level Dimensions - Need Help
Cadman5540
Wow!!  That's awesome!  Thanks for the help!!
Sat, Mar 10, 2018 at 6:28:37 AM | Level Dimensions - Need Help
Look, maybe dgcad was a little blunt but he is right.   You need to learn some basic fundamentals before jupping in with both feet like you question reveals.  To just answer you is not what you need.  Revit is not CAD and thinking/doing CAD processes will give you all sorts of problems.  Spend some time learning at least the basics of Revit - Start with some good Revit fundamental books or/and cadclips or better off, some outside training.
Mon, Mar 12, 2018 at 9:27:46 PM | Level Dimensions - Need Help
Cadman5540
Ok,  just to show you guys I kind of know what I'm doing.   Here's an addition I did over the weekend.
It's not perfect, but it's not bad.   Your comments are welcomed!
Thanks.
Tue, Mar 13, 2018 at 7:49:48 AM | Level Dimensions - Need Help
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You don't have anything attached.  But back to your original question of "Is there a way I can manually change the dimension text without changing the walls/and linked items?"  The answer is no,  you can't "fake" things in Revit like that and you shouldn't.
Tue, Mar 13, 2018 at 8:36:28 AM | Level Dimensions - Need Help
Cadman5540
Ooops!   Here it is.
Teofoe5, thank you for your reply.
Edited on: Tue, Mar 13, 2018 at 8:43:22 AM
Edited on: Tue, Mar 13, 2018 at 9:05:13 AM
Edited on: Tue, Mar 13, 2018 at 9:06:11 AM
Edited on: Tue, Mar 13, 2018 at 9:07:46 AM
Edited on: Tue, Mar 13, 2018 at 9:09:29 AM
Dimensions
Mon, Oct 3, 2005 at 4:44:59 PM
Copy Dimensions
Fri, Oct 10, 2008 at 7:26:58 AM
Level Test & Dimensions
Sun, Aug 31, 2008 at 6:41:42 AM
columns wont host to level
Tue, Feb 27, 2018 at 3:59:01 PM
Change spot elevation dimensions 0.00 coordinate
Sat, Feb 4, 2012 at 10:56:05 AM
Page generation time: 0.2271
