Forums >> Revit Building >> Technical Support >> Managed links -Autocad paper space
Wed, Mar 7, 2018 at 7:35:53 AM | Managed links -Autocad paper space
johnfin
I have a linked autocad drawing that is a paper space drawing and it looks ok when loaded BUT when someone opens the central file it needs to be opened again. Is there a way to get this to stick to its not a hassle to load it everytime?
Wed, Mar 7, 2018 at 2:29:50 PM | Managed links -Autocad paper space
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I don't quite understand the problem or question.
As far as I know REVIT kind of ignores autocad Paperspace elements (title block, view ports etc) and only shows the model space elements which is where the lines, dimensions and text etc exist. Maybe make sure the CAD file is last saved in model space instead of paperspace to start with ?
You should not be opening the central file you should always make a local copy of the central file and once again as far as I know it just shows the linked autocad model spece elements.
Maybe the question needs to be re phrased ?
The process should be.
Save the CAD file in model space with zoom extents and 0,0,0 can't be too far away
Start REVIT, open a local copy of the central file.
Link in the CAD file and position accordingly.
Put the CAD file on it's own workset.
Pin the CAD file so it cannot be moved accidentally.
Save the REVIT file, sync and relinquish and close it the file.
Start REVIT, create a new local copy of the central file and everything should be there with no additional re-loading required.
DG
Thu, Mar 8, 2018 at 8:12:11 AM | Managed links -Autocad paper space
johnfin
You are wrong, revit WILL link paperspace geometry. Do it all the time.
Thu, Mar 8, 2018 at 8:21:28 AM | Managed links -Autocad paper space
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Lol. Note that I said 'kind of ignores'. Which it does. Unless you specify all you see is modelspace stuff. Let's not get into a pissing match over this little topic.
Importing Paper Space/Model Space from CAD File
Mon, Nov 17, 2014 at 9:46:02 AM
Importing .dwg Details - Model Space vs. Paper Space
Wed, Aug 9, 2006 at 5:37:45 PM
HELP: getting "Import Geometry Not Visible" error message when linking DWG file
Fri, Aug 17, 2018 at 8:29:02 AM
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
Revit 2012 Sheets & Model Space / Paper space in CAD
Wed, Jun 12, 2013 at 6:36:59 AM
Page generation time: 0.1071
