Forums >> Revit Building >> Technical Support >> Keynotes "Filter by Sheet" not working
Tue, Mar 6, 2018 at 2:26:09 PM | Keynotes "Filter by Sheet" not working
rfender
REVIT 2018, Keynotes on sheets will appear if "Filter by Sheet" is unchecked... but all the keynotes show up on all sheets that have the Keynote Legend attached.  When checking the box on the "Filter" / Edit option of the Keynote view, all the keynotes disappear from the sheets.  I've beed searching Autodesk Help and it seems there was some issues back a few versions ago, and some work arounds that involved playiing with the view range.  But those suggestions didn't work either.  There have been other posts that relate to my situation, but only relate, not the same issue.  One other thing, I'm using a custom .txt file with my own Keynotes.  The same file has worked for years.  But I think that the problem did start a few versions ago.  Using the default file that comes with Revit does the same thing.
Keynotes Filter By Sheet Not Working
Wed, Aug 25, 2010 at 12:47:35 PM
Keynotes (CSI) and General Notes - combining on one sheet
Mon, Jan 24, 2011 at 12:29:35 PM
Keynotes
Mon, Mar 15, 2010 at 3:34:00 PM
Keynotes filter by sheet and default graphics
Mon, Jan 8, 2018 at 3:40:58 PM
Revit 2015 - Filter Note Block Keynotes by Those Visible on a Sheet
Sun, Mar 4, 2018 at 2:08:58 PM
Page generation time: 2.0569
