25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Phasing - used to produce multiple drawings
5 Posts No Rating |
I have nominated elements as existing, demolition and new construction in Revit.
I would now like to simply create a couple of drawings off the same plans (sounds simple) by changing the phasing in the 'sheets'.
When I place my plans into sheets they become unavailable to new sheets, so I cannot use 1 sheet for demolition then another for new construction (using the same plans).
any help would be appreciated
----------------------------------- regards
JebG |
Yo have to duplicate the existing view by right clicking on the plan<duplicate & then change phase in view properties to demolish. Same for the proposed view. You will have 3 seperate drawings from the same view.
Macca Sunshine Coast QLD Australia |
Using Revit Structure to produce Steel Fabrication Drawings (shop drawings) |
Sun, Feb 24, 2013 at 1:00:00 PM
Can the linked revit drawings preserved its phasing setting in master site plan? |
Fri, Apr 4, 2008 at 8:58:29 PM
levels - phasing |
Thu, Nov 8, 2012 at 7:14:22 AM
car and tree families for plan, section and elevation drawings |
Mon, Apr 21, 2014 at 9:34:09 AM
Multiple Sets of drawings |
Thu, Jun 25, 2015 at 1:10:41 AM
