Forums >> Revit Building >> Technical Support >> Current 3d PDF converters?
Mon, Mar 5, 2018 at 10:15:36 AM | Current 3d PDF converters?
Pdoak
Does anyone have any up-to-date 3d PDF converter recommendations? I've found a few threads and general google info but a lot of the reviews I've seen are several years old. So if you have a recommendation I'd love to hear it!
Thanks!
Mon, Mar 5, 2018 at 3:41:48 PM | Current 3d PDF converters?
Your question is not clear to me.
Revit can print to a 3D DWF or a 3D PDF with the correct PDF program..
Mon, Mar 5, 2018 at 5:18:39 PM | Current 3d PDF converters?
Pdoak
Sorry, exporting a 3d PDF from within Revit using a 3rd party software. I've used a couple in the past but has been a few years, and I was never terribly happy with the visual results, but functionally was great.
Mon, Mar 5, 2018 at 6:03:09 PM | Current 3d PDF converters?
Adobe is still probably the #1 program.
Mon, Mar 5, 2018 at 9:28:29 PM | Current 3d PDF converters?
Pdoak
In what manner does a person export a 3d pdf from Revit using Adobe?
Tue, Mar 6, 2018 at 6:54:16 AM | Current 3d PDF converters?
https://bim.wikispaces.com/Revit+to+3D+Pdf+-+BIM+Functionality
Tue, Mar 6, 2018 at 8:55:15 AM | Current 3d PDF converters?
Pdoak
Great, I'll check it out! It was my understanding Adobe no longer made an extended version that supported this, it's possible I was given bad information though, or simply cannot find it.
Thanks!
Mon, Mar 12, 2018 at 11:31:12 AM | Current 3d PDF converters?
Pdoak
From what I've been able to tell, there is no longer an Adobe Pro Extended version, only Adobe DC which is available on the cloud, which does not have the ability to import an ICF file (unless there's some work-arounds you have to do in order to get this to work). Anyone have any other suggestions as to what works for you?
Tue, Mar 13, 2018 at 4:33:21 PM | Current 3d PDF converters?
surfingjp
There are a vew plugins to export from revit to OBJ and use MeshLab to save as a U3D, you should be able to import that into Adobe.
3D PDF from Revit, Navisworks or 3D DWF
Tue, Sep 13, 2011 at 9:11:45 PM
11
after revit export to pdf the file is wrong scale
Sat, Nov 20, 2010 at 10:54:04 PM
Exporting to PDF results in blank page
Wed, Apr 30, 2014 at 3:24:27 PM
REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND??
Thu, Nov 4, 2010 at 9:43:22 AM
PDF File Names
Thu, Apr 7, 2011 at 8:37:37 AM
Page generation time: 3.4301
