Forums >> Revit Building >> Technical Support >> Cropping drafting view
Fri, Mar 2, 2018 at 3:09:16 PM | Cropping drafting view
johnfin
Since you cant crop a drafting, and I want to bring in wall sections from autocad they were cropped, can I bring them into another type of "view" or is there a way around it.
Fri, Mar 2, 2018 at 3:28:48 PM | Cropping drafting view
The following are all ideas but I consider them to be bad....
  1. All model views are cropable so you could create say a plan view way out in space, where it will not interfere with anything, to place your CAD,.
  2. This one will cause you sheet nightmares.   A rectangle within a rectangle masking region creating a window.
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Would like to copy a drafting view from one project to another. [ 1 2 ]
Mon, Jan 4, 2016 at 6:07:17 PM
17
Rebars - Stirrups Tie in Drafting View
Wed, Aug 1, 2012 at 9:47:36 AM
Trouble copying detail items from Section View to Drafting View
Mon, Aug 19, 2013 at 1:08:05 PM
Using a callout on a drafting view
Fri, May 16, 2008 at 10:39:58 AM
Page generation time: 2.0322
