Forums >> Revit Building >> Technical Support >> cantilevered stone stairs
Wed, Feb 21, 2018 at 2:39:08 PM | cantilevered stone stairs
CoreHome
Hello,
My boss is wanting to do cantilevered stone stairs as seen in the attached image.  I feel they're similar to precast stairs, except that the underside has a profile.  I've been trying to dig into how the precast stairs are constructed, but can't figure it out.  I see the option in precast stairs to have a stepped or sloped underside, which is what I really need to modify.  I tried a custom stair profile, but that didn't work.  Maybe custom front and underside profiles, but where do the go in Revit.  My next thought would be to use Revit to generate the precast stair to get me the profile, then use the profile to build custom family and sweep my profile across each tread.
Thoughts?
MikeRevitLT 2018
Thu, Feb 22, 2018 at 12:20:17 AM | cantilevered stone stairs
tim123
4 Stars: 19 Votes
You can choose to not have risers, and use a profile for the stair treads - I have just replaced it with a random profile, but this can be anything that you want.
Thu, Feb 22, 2018 at 2:30:39 PM | cantilevered stone stairs
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Revit's stair tool is great for basic stairs, but when a stair becomes a little complex and needs a lot of flexibility, I always bin the stair tool and build the stair as an in-place family or as a independent family. You can spend hours and hours trying to bend the limited coding of the stair tool but making it a family you can instantly 3D model any shape you need for stringers, soffits, treads and railings.
How do you make cantilevered Roofs?
Mon, May 15, 2006 at 7:17:59 PM
Stone Walls, Stone Veneer, etc
Fri, Oct 6, 2006 at 8:21:58 AM
Tapered cantilevered beam with openings
Mon, Aug 14, 2006 at 5:06:16 AM
cantilevered steel balconies
Fri, Aug 3, 2007 at 9:25:58 PM
Stone Wall
Tue, Aug 20, 2013 at 3:55:33 PM
Page generation time: 2.0394
