25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Door and Window Tags in Legends
26 Posts No Rating |
I'd really like to tag all my doors and windows in my Legends...the elevation sheet of all the project doors and windows.
How is this accomplished?
I would like to do this also. Using Revit 9.1. Is it possible or do you have to make symbols to look like the tags?
I have spent hours trying to figure this out with RAC 2008. It appears the only solution is to create a "dummy" tag that allows you to edit the text on an INSTANCE basis. Of course the problem is that it is not tied to the same information in the door/window data. So if you change the type mark of a window in either plan, elevation, schedule, or element properties, it WILL NOT update in the window legend. This should be at the top of Autodesk's list for next release improvements as it is counter to what Revit is all about.
----------------------------------- Revit Architecture 2010 |
Window & Door Legends |
Thu, Sep 10, 2015 at 12:41:54 AM
Window legends |
Fri, Dec 31, 2004 at 8:35:39 AM
Creating Window or Door Legends |
Wed, May 3, 2006 at 10:30:16 AM
Door and window tags |
Thu, Nov 3, 2011 at 8:51:34 AM
Room Window and Door Tags |
Thu, Nov 15, 2007 at 9:21:10 PM
