Forums >> Revit Building >> Technical Support >> Drawing list
Mon, Feb 12, 2018 at 8:26:30 AM | Drawing list
johnfin
How can I get selected drawings to show up in the generated drawing list. Saw you set up the entire project but only want to show a schematic design set in the list.
Mon, Feb 12, 2018 at 12:38:17 PM | Drawing list
marmiketin1
4.5 Stars: 10 Votes
You need to use filters to help you select only certain drawing sheets. For example if you have all you schematic drawings number with SD in front then you can filter by sheet name - contains SD and then only sheets with SD in the name will populate your list. There are several different ways to filter and selection criteria to use so it all depends how you want to do it.
Revit Drawing List
Tue, Mar 15, 2011 at 5:20:07 PM
Drawing List's
Wed, May 26, 2010 at 11:49:42 AM
Adding a check box list to a drawing list
Thu, Apr 21, 2016 at 5:17:56 PM
Column sizes in the Drawing List
Mon, Jul 13, 2009 at 2:24:16 PM
Drawing List
Thu, Feb 8, 2007 at 12:57:50 PM
Page generation time: 6.5090
