18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> New Title Page Label Using Project Information
I want to create a label that's linked to the project information (Client Name, Project Name, Project Adress, Project Status) that appears ONLY on the Title Sheet (centered at the top of the page). I can create a label while in the Titleblock family that links to the project information, but it will appear on every sheet in the set.
When I try to embed a label so that I can toggle the visibility of the label, I cannot define the parameters using the project information. I can only define it using Name, Discipline, Type & Group. I was hoping that the Project Info was a shared parameter rather than a system parameter.
Is my only option to write this as text (no label or parameters, not linked to project specific information)?
You need to create a new sheet for this just like you do for your normal sheets. Save it in your library as ....Title Sheet 24x36? or whatever.
I have a titleblock family with all the standard project info (project name, address, client, etc...) in the banner on the. I also added large labels at the top center of the page with the same project name and address parameters. I could assign a visibility parameter to that label (type parameter). Then in the family, i created 2 family types... one called Cover Sheet and one called Standard, and i set the visibility for the large label to be on in the one type and off in the other. Works simple.
Is your label on the top center of the title page linked to the system parameter - project information? from what I've read and videos watched, Is embedding a label or image into the title sheet the only wat to get the visibility toggle checkbox?
Yes. It is a label linked to the project information. I think that's what you were trying to do. See the .rfa... you can see if that helps. It's pretty straightforward.
Thanks. I was getting stuck because a video was saying that I had to use a nested family to get the visibility parameter. Didn;t think to load two titleblock families one with the label and one without.
Project Address Label |
Thu, Feb 8, 2018 at 1:37:25 AM
Titile block label |
Tue, Sep 16, 2008 at 11:15:27 AM
Revit 2009: Custom label in title view & Reference sheet |
Mon, Dec 8, 2008 at 7:09:23 PM
Title sheet label |
Wed, May 7, 2008 at 12:17:41 PM
Mult-line or Memo field in Title Block label |
Wed, Aug 31, 2011 at 9:19:09 AM
