Forums >> Revit Building >> Technical Support >> brindle material
Wed, Jan 31, 2018 at 10:32:02 AM | brindle material
OmiD7005
hi
how can I have a brindled material on my wall?
I need to repeat two images (horizontally) in every 5cm
Thu, Feb 1, 2018 at 3:43:49 AM | brindle material
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Search on google for seamless brindle and find the one you want. If you can't find the one you want, you will need to make it in Photoshop - such that the right hand side of the image will seamlessly blend into the left hand side of the image and the same for the top and bottom. You then need to create a new material, setup a pattern that matches and create a texture pattern that uses the seamless brindle image you found/made. You then need to create a wall type wtih this material as a layer finish.
You could also create decal using the image. Decals are better used for paintings on walls rather than full wall coverage.
Sun, Feb 4, 2018 at 1:09:24 AM | brindle material
OmiD7005
Thanks
Revit 2013 Material User Interface
Thu, May 2, 2013 at 4:50:53 PM
how to know the material used in a specific object?
Mon, May 9, 2011 at 1:14:23 PM
Material troubles when duplicating a material
Mon, Dec 12, 2016 at 8:47:07 PM
Question about shared custom material library
Wed, May 18, 2016 at 6:44:31 AM
Revit 2013 Material Creation
Fri, Mar 15, 2013 at 3:35:40 PM
Page generation time: 1.2348
