Forums >> Revit Building >> Technical Support >> DOOR SCHEDULE LEVEL NAME
Sun, Jan 28, 2018 at 7:09:13 AM | DOOR SCHEDULE LEVEL NAME
UrbanDesign69
Is there a way to have the door schediule level show as a single digit rather than "1st Floor Plan"?  I don't want to change the level name on the other sheets.
Thu, Feb 1, 2018 at 4:10:09 AM | DOOR SCHEDULE LEVEL NAME
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Nope. You're gunna have put up with it as it stands. Revit's data is interconnected to the 3D geoemetry. Its good as it means a single change, makes a universal change across the model but its bad in that its a little less flexible. It is what it is.
Thu, Feb 1, 2018 at 6:53:18 AM | DOOR SCHEDULE LEVEL NAME
You can also add a parameter to doors that you fill in for this.
sort door schedule by level without adding "level" column?
Tue, Aug 15, 2017 at 11:27:04 AM
Revit 2011 - Curtain Wall doors on Schedule for correct level
Thu, Jun 7, 2012 at 1:22:49 AM
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
Door Schedule
Fri, Aug 17, 2012 at 7:07:50 AM
Linked door schedule sorted by level
Fri, Jun 26, 2015 at 8:06:46 AM
Page generation time: 5.2577
