Forums >> Community >> Newbies >> New in revit
Thu, Jan 25, 2018 at 12:05:03 PM | New in revit
glenn1979
Need some help, i dont want to see some lines in elevation and in 3D, I make a stacked wall height of 2200mm the 400mm concrete and the wall again it turn out good in section but when i see it in 3d or in elevations i can see the lines
Thu, Jan 25, 2018 at 12:20:33 PM | New in revit
glenn1979
Also need hepl on this one, the first image is from autocad architecture and i just ue the break command wall and put a colom in between but when i try it in revit like i saw in some videos on you tube, the colom tur part of the wall and turn black i needed to show that there is a colom in the wall, how do I do that?
Fri, Jan 26, 2018 at 5:23:45 AM | New in revit
4 Stars: 205 Votes
1º Question: http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-8979FAF8-8E25-4977-BFC8-0C065654CD0E
2º Question: http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-5B2C8F82-A711-46B8-BF90-A54D567B435F
Sun, Jan 28, 2018 at 9:18:33 AM | New in revit
glenn1979
Thx Typoon!!!!   I was able to clear the Colomn problem on the floorplan, but the lines on the elveation not yet but I will keep playing around in revit
Sun, Jan 28, 2018 at 9:54:08 AM | New in revit
glenn1979
this is the custom wall i made its simple but the concrete some how you see the lines in the elevations
Sun, Jan 28, 2018 at 10:08:54 AM | New in revit
glenn1979
Holly crap, Thx Typoon I manage to fix the line problem in elevations thx man
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:24 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
Page generation time: 1.5187
