Forums >> Revit Structure >> Technical Support >> Shared Levels & Worksets
Wed, Jan 24, 2018 at 10:09:48 AM | Shared Levels & Worksets
KraigZ
Working on a project using Revit, and the colaberation of Revit models using BIM 360 Team, i seem to always forget to put things on their rightful workset as i am modeling them. Is there a way to make it so that every time I place a new level, it atomatically goes to the Shared Levels & Grids Workset? or Everytime I place a beam or Coulumn it is assigned a workset I had created?
Thank you for your time!
-KraigZ
Wed, Jan 24, 2018 at 1:11:16 PM | Shared Levels & Worksets
No way to have Revit think for you - too many rules to define that.  This is a discipline that you have to learn and emphsize toother team members.  The model/file is only as good as you make it and you need to be able to trust the model.
What I do is I review our file often lookinf for miss placed elements.  For most 3D work, I use a 3d view with all worksets off then I turn on one at a time.  I do the same with plans and where appropriate, elevation and sections.  It doesn't take look when done regularly.
Groups & Worksets
Sat, Dec 15, 2018 at 9:00:15 PM
WORKSETS
Fri, Apr 17, 2009 at 10:37:22 AM
Worksets - Is there a way to?
Tue, Nov 4, 2014 at 12:51:46 PM
Schedules & Levels
Fri, Feb 24, 2006 at 2:08:54 PM
what is the fastest way to turn off annotations for linked revit files?
Tue, Nov 17, 2009 at 3:22:16 PM
Page generation time: 1.5879
