Forums >> Revit Building >> Technical Support >> Exporting to DWF with Phase Filters.
Wed, Jan 24, 2018 at 9:47:06 AM | Exporting to DWF with Phase Filters.
JBRADLEY
Using REVIT 2017.   I have models created with "existing" and "New" phases set up.  When I export to DWF, some of the objects that are on "existing" phase are not showing up on the dwf until i zoom in closer.   It's like Design Review isn't regenerating everything?  This only happens on models using Phasing.  Is this a graphical issue and is there anyway to correct this?   Also, the "Existing " Phase is set to Halftone.  But, other linework that is halftone has always worked before....   Not a big deal, but annoying.  Any thoughts?
Thu, Feb 1, 2018 at 4:11:45 AM | Exporting to DWF with Phase Filters.
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
try pdf?
Thu, Feb 1, 2018 at 8:13:52 AM | Exporting to DWF with Phase Filters.
I imagine it is a 'double whammy'... You set exiting to grey and the dwf filters that as well.  What happens if you remove your grey filter?
3D DWF Exporting in 9.1
Wed, Feb 7, 2007 at 3:39:28 AM
3d DWF export
Wed, Apr 4, 2007 at 10:32:34 AM
Walls layers + phase filters display problem
Wed, Dec 21, 2005 at 5:40:14 PM
material patterns rotate when exporting to a DWF revit 2015
Thu, Jan 22, 2015 at 12:41:59 PM
phase filters
Thu, Mar 27, 2008 at 11:07:54 AM
Page generation time: 0.4501
