Forums >> Revit Structure >> Technical Support >> Nestled family does not control the visibility
Mon, Jan 22, 2018 at 3:14:11 AM | Nestled family does not control the visibility
Erdem01
Dear forum members,Hope you guys have an solution for this.I'm struggling with the visibility parameters. I have 1 host family with an nestled family in it. The nestled family controls 4 object (visibility on/off depending on length)The host family controls the nestled family (simple yes/no checkbox parameter)When i use the "preview visibility mode" in my host family, everything works fine. Depending on length (1572 / 2072 / 2572 / 3072mm ) and length other then those 4, the nestled family keeps invisible.But when i use the host family in an project, the nestled family visibility parameters doesn't work.
I added my family (L.A. Ligger.rfa as an Attachment, start an new structure project an try the family). Maybe you guys see the problem.Thanks for the help. ( out of the box question, can i make an z justification parameter fixed to origin? thanks )
Element Visibility Setting in Project
Mon, Jan 25, 2010 at 11:57:33 AM
Symbol in family visibility
Tue, Nov 3, 2009 at 9:00:07 AM
Using Visibility Graphics to control elevation callouts
Wed, Nov 12, 2008 at 9:58:42 AM
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
Visibility Control for Imported CAD Models
Fri, Sep 10, 2010 at 12:49:06 PM
Page generation time: 5.3896
