Forums >> Revit Building >> Technical Support >> Level's elevation Base - Survey Point
Mon, Jan 15, 2018 at 10:09:42 PM | Level's elevation Base - Survey Point
glenlake
3.5 Stars: 3 Votes
Please help – Levels and the survey point
Please help!
My PBP and the survey point are at different altitudes.
When I change the level’s Elevation Base from the PBP to the survey point and vice versa, the elevation value remains the same.
What am I doing wrong? (use Revit 2017)
Thank you.
Tue, Jan 16, 2018 at 8:11:02 AM | Level's elevation Base - Survey Point
GHlen,
I know you watched those videos I posted a few years ago so I am assuming you are following that advice.  So, how are your levels set?  Look at their reference.
Tue, Jan 16, 2018 at 10:27:47 PM | Level's elevation Base - Survey Point
glenlake
3.5 Stars: 3 Votes
I'm pleased you remember me.
I watched this video again, -- it's a good one.
 One level type is set from the PBP, the other one -- from "Reference". or Survey point.
The PBP is much above the Survey point. But both levels do not change the value of elevation, npthwithstanding i change their types (and, correcpondingly, their base level).
Both PBP and Survey points are clipped.
 Thank uoy.
Topography Elevation from Project Base and Survey Point is Incorrect
Thu, Jan 29, 2015 at 10:32:24 PM
Spot Elevation/ Level with both "project base point" and "survey point" 2017
Mon, Nov 27, 2017 at 5:33:42 PM
Level that reads both Project Base Point and Project Survey Point
Tue, Jun 9, 2015 at 9:39:37 AM
Display both Project Base Point and Survey Point on Elevation Datum.
Fri, Aug 29, 2014 at 5:57:41 PM
Project base point/ Survey Point
Tue, Nov 13, 2012 at 3:35:36 PM
Page generation time: 3.6495
