Forums >> Revit Building >> Technical Support >> Revit 2016 - Multiple Drawing Sets in Sheet Index
Thu, Jan 11, 2018 at 1:51:06 PM | Revit 2016 - Multiple Drawing Sets in Sheet Index
alclaxton
Is there a way to have multiple drawing sets show up in your drawing index? We have a project that is 7 floors and will be permitted by floor, so we have separated the sheets into CD sets per floor, ie-CD - 10th Floor.....but we have kept a general CD set that has the general sheets that will go in all sets. Any way to have the sheets in CD and CD - 10th Floor show up in my drawing index?
Thanks
Fri, Jan 12, 2018 at 10:38:33 AM | Revit 2016 - Multiple Drawing Sets in Sheet Index
When we had multiple drawing sets, we added a prameter that we could use to sort the sheets in seperate sheet indexes.  Some sheets were used by more than one set but that was no problem by having more than one "set parameter' assigned to each sheet.  We also had a combined sheet index.
Links to each sheet in sheet index
Sun, Aug 21, 2016 at 11:06:31 AM
Sheet / Drawing Index / List Check Box
Thu, Dec 18, 2008 at 8:48:15 AM
Multiple independent sheet index for cover sheet
Tue, Feb 4, 2014 at 8:28:13 AM
2017- adding mutliple revisions to sheet index
Mon, Apr 15, 2019 at 3:29:19 PM
Combine multiple sheets into a single PDF file per THE SHEET INDEX
Fri, Jul 31, 2015 at 3:00:27 PM
Page generation time: 3.9571
