10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> V. 2018 - cutting wall sweeps with void forms for stadium seating
0 Posts No Rating |
Hello. My searches for info on this topic have not answered my question, so sorry if this is a repeat. I am a new user to Revit and am learning on my own as I go.
I am creating indoor field-house seating, circular, by using a wall sweep profile. I have several areas where the lower walls transect the seating area and the sweep need sto be cut to reflect this. I have tried to create a void using a lines traced at the proper cutting-wall faces, but I am unable to get anything to work. The void is not created as it doesn't intersect object.
See the attached PDF - The green lines to the left are copies of the tracing I am using to create my void form.
Any help I could get would be greatly appreciated. Links to existing reference material are welcome.
Thanks for your attentiuon.
Edited on: Wed, Jan 10, 2018 at 12:41:01 PM
If you remade it as an inplace family and used void shapes to cut the revolved solid that should work.
0 Posts No Rating |
Thank you, but I am unclear as to which element needs to be remade. The rotated wall sweep, or the void form? I just tried both and neither allowed me to finish the process. I am afraid it may be how I am approaching the problem - my lack of experience is messing with my set-up.
Is there an on line video tutorial that walks through a setup procedure? I have looked but haven't found anything That helped, but maybe I am using the wrong search terms.
Beau's suggestion is to not use wall sweeps. A better and far easier solution is to use an in-place family - a rotated form, then to use your void to cut that.
0 Posts No Rating |
OK, I see now. I just needed two people to explain it - that is often true for me. Thank you both!
stadium style seating |
Thu, Apr 30, 2009 at 9:36:58 AM
pattern issue-void cutting through wall and sweeps |
Fri, Sep 23, 2011 at 2:24:08 PM
Cutting wall end with in-place void - Revit 2018 |
Thu, Jul 6, 2017 at 5:08:30 PM
Trouble with void forms and parametrics in families |
Mon, Jul 4, 2011 at 9:28:29 AM
Cutting irregular openings in curved walls |
Sun, Apr 9, 2006 at 7:45:39 PM
