Forums >> Revit Building >> Technical Support >> Constraining a group parameter to reference levels
Thu, Jan 4, 2018 at 12:15:00 PM | Constraining a group parameter to reference levels
BRITTANY11
I'm having trouble figuring out how to make this work.  I've created a new family for built-up wood columns. I have an array parameter linked to "Number of Ply's" where when entering 2 gives me a 2 ply column, 3 gives me a 3 ply column etc. This is working great; however my trouble comes when trying to extend the height of the group. I cannot seem to figure out how to apply lower and upper reference levels to this group.  They stay at the set height of my extension, when I try to drag the upper reference level the lower level moves up and maintains a consistant height. Revit is not allowing me to contrain the height of grouped objects.   Please help!
I've got the same issue with a built-up beam family I've created; I've got no problem getting the number of plys to display but the beam stays at a constant length!
Wed, Jan 10, 2018 at 5:00:30 AM | Constraining a group parameter to reference levels
tim123
4 Stars: 19 Votes
I can't open your file, as I'm still on 2017, but I suspect that the end ply is not constrained.  In you array, constrain the first and last ply to the reference height.
Constraining a circle centered between two reference planes
Fri, Apr 7, 2017 at 8:22:50 AM
Angle parameter for column?
Thu, Jan 23, 2014 at 5:38:28 PM
"group parameter under" changed upon loading into project
Wed, Aug 11, 2021 at 3:16:03 PM
Constraining a Model In Place Wall
Fri, Jul 5, 2013 at 9:14:23 AM
Group Instances at different "levels"
Wed, Apr 3, 2013 at 7:24:32 AM
Page generation time: 1.3595
