Forums >> Revit Building >> Technical Support >> turning off hatch pattern of certain wall layers
Fri, Dec 29, 2017 at 11:28:03 AM | turning off hatch pattern of certain wall layers
brankulo
i have a wall which consists of stucco over rigid foam on 2x6 studs with gyp interior. all these layers have hatch assigned to them.
now how do i achieve the following:
in floor plans i dont want to see any hatching except rigid foam.
in sections i want to see all hatching except 2x6 stud layer.
is this even possible? in VG, i am only able to turn on/off hatch for all wall layers together.
thanks
Sat, Dec 30, 2017 at 10:13:39 AM | turning off hatch pattern of certain wall layers
broadtechengineering
Hi BrankuloI briefly wen through your requirements. I think I can help you with that
BroadTech Engineering | Your Trusted Engineering Simulation Company
CFD Consulting | CFD Simulation | Computational Fluid Dynamics Consulting Services
Seperating layers hatch with filter
Wed, Feb 12, 2014 at 3:15:30 AM
Turning brick hatch pattern off in a wall section.... is it possible?
Mon, Jan 29, 2007 at 2:01:27 PM
Vertical hatch pattern line alignment on wall ends
Wed, Mar 14, 2012 at 10:04:07 AM
CMU Hatch Patern
Sat, Jan 31, 2009 at 4:00:05 AM
Getting Cut Wall Hatch to move WITH the Wall
Fri, Aug 10, 2012 at 2:59:50 PM
Page generation time: 0.8584
