14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Trying to make a Dutch Windmill - Havekes Mölle in Twello the Netherlands
6 Posts No Rating |
Trying to make a Dutch Windmill - Havekes Mölle in Twello the Netherlands and I have problems with the top roof.
From an old drawing and a lot of photos I made the shape. And I think it is not to bad... But the moment I try to change it into a mass object it goes terribly wrong.
My problem is only with turning part of the top.
Why do you want to change it to a mass?
6 Posts No Rating |
it is a thachet roof with a thickness of about 250 mm. I only have a thinkness of... 0 mm - and I can't change my material.
And I would love to learn how it works. just to know.
I'm not shure if I understood you, but if the thickness is your problem, dont change the material, change the structure of the roof, just like you do wiht floors
I have a couple of thoughts...
- I suggest you tell us more about your process, maybe we can help you there. I will not be opening your families.
- I don't understand why you 'can't' apply a material.
- Material thickness - Is that really an issue here? Why do you need that? If you need that, they why didn't you already create it?
A dutch mill with an inside out problem |
Thu, Jul 18, 2019 at 3:49:01 AM
dutch gable in roof |
Tue, May 29, 2007 at 11:28:04 PM
Dutch Door... Can't seem to find it anywhere... |
Tue, Jul 31, 2007 at 7:51:11 PM
Dutch Gable Roofs |
Tue, May 19, 2009 at 12:35:08 PM
Translating a project |
Thu, Nov 24, 2016 at 4:28:58 AM
