Forums >> General Discussion >> Revit Project Management >> Export from Revit To CAD with RELATIVE linked files
Wed, Nov 29, 2017 at 11:00:35 AM | Export from Revit To CAD with RELATIVE linked files
cchilton
Revit 2018 local project file with several discipline models linked.
Need to export CAD backgrounds with the linked Revit models as links in the CAD file instead of one CAD file with those disciplines backgrounds comming in as blocks.
On the Export Options menu you can only check/uncheck wheter you want them as linked references or not.
In order for my team to use the backgrounds I have to open each source CAD file and change the linked files to relative path....thats a time consuming step.
Is there a setting or patch which will create the linked cad files as relative path instead of absolute references?
Thanks
export dwg including a linked revit file
Tue, Jul 31, 2012 at 12:30:21 PM
Linked CAD files are not turning off
Tue, Nov 29, 2016 at 3:31:28 PM
14
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:43 AM
Export Revit Files into CAD
Mon, Sep 23, 2013 at 7:58:20 AM
Problem exporting view with linked CAD file
Wed, Mar 18, 2009 at 3:46:34 PM
Page generation time: 2.9058
