Forums >> Revit Building >> Technical Support >> Spot Elevation/ Level with both "project base point" and "survey point" 2017
Mon, Nov 27, 2017 at 4:57:22 PM | Spot Elevation/ Level with both "project base point" and "survey point" 2017
ledgewood33
I am looking for a family or to create a family that shows the "project base point" (relative) and "survey point" (sea level) for either spot elevation and/or a level?
or if someone has figured out a work-around?
Mon, Nov 27, 2017 at 5:33:42 PM | Spot Elevation/ Level with both "project base point" and "survey point" 2017
Read the similar threads below.
Topography Elevation from Project Base and Survey Point is Incorrect
Thu, Jan 29, 2015 at 10:32:24 PM
Spot elevation and "current level"
Fri, Feb 17, 2017 at 3:11:01 AM
Level that reads both Project Base Point and Project Survey Point
Tue, Jun 9, 2015 at 9:39:37 AM
Dimensioning to a "Point" at wall intersection in 2008
Wed, Jan 30, 2008 at 9:41:11 AM
"Modeling Topos" & Topo's from grade or point?!?! Topo Conceptual Mass?
Fri, Aug 4, 2017 at 5:52:31 AM
Page generation time: 1.5224
