8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> wall corners to automatically create extrusion
is it possible? i need to have void when i turn wall 90 deg in plan. this is for tilt up project and the way panels are joined is, there is miter with 3/4" gap at corners. thanks
Yes, you can create an in place void to show this.
i can, but it does not adjust when one of the wall are moved
You are correct, you can not make this automatic with an in-place family. There are some possibilities with a hosted family but I doubt that would be worth the efoort unless you have multiple projects and locations that need this.
Introduction / wall irregular shaped opening |
Wed, Mar 26, 2014 at 6:57:30 AM
Revit 2012 Roof by extrusion |
Sat, Nov 19, 2011 at 4:49:20 AM
Wall joins (or wall corners) |
Sun, Nov 18, 2012 at 10:40:59 PM
Curtain wall corners |
Sat, Apr 5, 2008 at 12:45:04 AM
metal wall panels with rivets at the corners |
Sat, Jul 28, 2007 at 10:53:01 AM
