Forums >> General Discussion >> Revit Project Management >> How to start a new project using everything from an existing one?
Fri, Nov 24, 2017 at 2:43:33 PM | How to start a new project using everything from an existing one?
juca64
Hi
I am relatevly new Revit user I been working with revit but never start a project from scratch. Now I have to do so, I have already an existing project with all the parameters, fanilies and templatesI want to keep using on the new project, how is the secure and clean process to start using all of those things.
Thanks for any hint, I really appreciate in advance any help.
Sat, Nov 25, 2017 at 6:10:32 AM | How to start a new project using everything from an existing one?
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Ok, I won't lie but there is a lot of work to do. You may be better off starting your new project from scratch using your office template and transferring across anything you need using the Transfer Project Standards tool.
However if you want to know what you need to do to reuse an existing project then do as follows:Detach and save as the original model. Delete everything 3D in the model (unless there are parts you want to keep).
Change project information parameters.
Delete any drafting views you don't want.
Remove all existing links like rvts, dwgs, images, ifcs and point clouds.
Don't purge.
A model does build up redundant content throughout a project's lifetime. You should dive in deep and delete out some of this. This will include line styles, line weights, fill patterns, region fills, materials, sheets, text types, project parameters, shared parameters, families, annotations, tags, 2D Groups, 3D Groups, Keynotes
You will need to reposition your project coordinates to your new site along with your project north.Remove phases and design options.
Resolve all warnings.
Review view templates, filters and color schemes and delete any you don't need.
Change your Location to your new site address in the Sun Settings.Remove redundant worksets.
There's probably more but I can't think of them for now.
Sat, Nov 25, 2017 at 9:27:28 AM | How to start a new project using everything from an existing one?
You will also want to delete all levels except for the first one, then delete all views - except for the first level plan and the 4 major elevations.
Sat, Nov 25, 2017 at 3:28:04 PM | How to start a new project using everything from an existing one?
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Thanks WWWHub...and delete grids
Edited on: Sat, Nov 25, 2017 at 3:29:00 PM
Creating new project from existing
Mon, Aug 22, 2005 at 12:16:53 PM
Stupid ? # 234 - project browser
Fri, Nov 20, 2009 at 1:23:50 PM
Should i use the existing Revit Model to create a new building addition?
Tue, Apr 19, 2011 at 8:07:22 AM
Levels - I need more
Thu, Nov 18, 2010 at 1:59:30 PM
Import existing Revit Building in New Project
Thu, Apr 7, 2016 at 12:55:01 PM
Page generation time: 1.4544
