19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Image applied in texture editor is inserted in the middle of surface
0 Posts No Rating |
I've created a sliding door panel, and when I attach an image for the panel finish it comes in centered on the door panel. How do I change the insertion point of the image file??? I'm using Revit LT 2014.
Is this image one item that should cover the whole door? If so then don't use a material, use a decal.
0 Posts No Rating |
The image is just supposed to cover the door panel, not the track or frame. I've never used decals before, can you pick which surface you want them to be applied to?
A decal is face based. If your panel is a seperate face, then the decal will only be placed there.
Be sure you understand decals... they only show in 3D views, not 2D elevations.
0 Posts No Rating |
A decal won't work then, I need the image to show up in a 2d elevation. Any other ideas?
You need to associate a model hatch with your material. Then you can use that in a 2D view to adjust where your pattern file is.
Look here and here and here.
Model surface pattern and material not aligned |
Fri, Jul 6, 2018 at 8:58:24 AM
Inserted Image not visible |
Fri, May 15, 2009 at 10:26:13 AM
Texture fix |
Mon, Jul 9, 2012 at 1:25:13 AM
Can't Zoom into Inserted Image |
Thu, Jul 1, 2010 at 5:06:11 AM
Locking inserted image/dwg file |
Mon, Aug 29, 2011 at 9:38:25 AM
