Forums >> Revit Building >> Technical Support >> Material tag and doors
Fri, May 26, 2006 at 6:06:07 PM | Material tag and doors
paulh
I'm having a small problem. I'm trying to tag the materials on my elevations. I created a custom tag using the Generic Tag template so I could make a material tag. The tag works fine on curtain wall and walls but when I try to tag doors it just shows a question mark and won't let me change the value. I've attached the tag to this message. Any ideas hwat is going wrong?
Mon, May 29, 2006 at 5:04:07 PM | RE: Material tag and doors
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Its because the material of the door is most likely a type parameter of the door. Type parameters cannot simply be clicked on and modified. You would need to edit the actual door and modify the material that way. If its the mark value you wish to change find out the material of the door, goto your material settings select the material and click on the identity tab. You can then give a mark value or any other information for that matter. HTH.
material tag
Tue, Jun 9, 2015 at 8:49:15 AM
no material tag in metric library
Wed, Aug 24, 2016 at 2:02:51 PM
material tag schedule problem
Sat, Mar 25, 2017 at 7:50:36 AM
Can't add shared parameter to material tag?
Mon, Jan 21, 2008 at 5:58:33 PM
tagging curtain wall doors
Mon, Jul 30, 2007 at 3:14:11 PM
Page generation time: 0.7574
