19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> need help with family
downloaded this folding door family from Kolbe website but no matter what i do i cant change the height of the door. i input 8' as my desired height but only door panel change and the frame and opening would remain at default height of 10'. i tried to open the family but it is too complicated for me to fix it. could somebody take a look to see if it could be fixed?
family attached. i am in revit 2017
thanks
Open the family and select the opening. When the sketch lines appear, make sure the line for the head of the door is locked to the reference line that moves when the height is changes.
For the frame, select the frame in the family editor, edit it and if it is a profile that follows a sketch line path, then edit the sketch line path and again make sure the line that runs along the head is locked to the reference line that moves when the height is changes.
...or use different family (third from the top).
https://www.marvin.com/support/technical-resources?brands=marvin&restype=dwg&doc=64&draw=32&prodCat=Door&prod=0
Create a family that includes another family |
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family? |
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project |
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message |
Wed, Aug 26, 2020 at 11:19:36 AM
Text(family #1) not showing after loading into family #3 |
Mon, Jan 19, 2015 at 2:43:21 PM
