15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> How to make family length visible in project
0 Posts No Rating |
This family I made with a line depent detail item. I need a dimentionline that:
- has no line (first i had made the line white, but than it covers other things in the drawing)
- has the two arrowheads near the length number
- gives the length automatical
When I use this family I have to manually enter the given length. But when my drawing changes noting is changing with it. This is very importand with this project. Can a family mastermind help me out here?
0 Posts No Rating |
I use Revit 2017
Instead of a family, did you consider just setting up a new dimension style where it had a prefix '<' and a suffix '>', no tick marks, text centered
0 Posts No Rating |
I have. But there where two problems:
- to let the line disapear i had to make the line white, but where the line covered an object i did see the white line. And also at the start and end there is a smal white thingy eventough i set al the settings to 0.00
- I had to insert the prefix and suffix all manually in the Dimension text. It is a huge project so this is not ideal.
Made you a family that does what you need. It is a line based detail item with a label annotation family inside it. I set the label text height to 2mm but you can change this in the family if you like.
0 Posts No Rating |
OMG!!! you are great! how can I thank you enough. Can I send you something?? Where do you live?
X, lies
Drawing length of family in project? |
Thu, Jul 10, 2008 at 7:00:32 PM
Variable Length Family with Array Formula |
Wed, Aug 8, 2012 at 9:56:46 AM
Creating a Beam Family Where Each Type has a Determined Length |
Wed, Aug 31, 2016 at 11:55:27 AM
11
Void in family not visible in Project. |
Tue, Oct 8, 2013 at 1:01:05 PM
Family Instance Parameter Dimension Help |
Wed, Apr 10, 2013 at 5:22:09 PM
