Forums >> Revit Building >> Technical Support >> ROTATE DRAFTING PATTERN WITHIN DETAIL ITEM
Tue, Oct 31, 2017 at 5:18:06 PM | ROTATE DRAFTING PATTERN WITHIN DETAIL ITEM
ledgewood33
I have created a plywood detail item that has a drafting pattern inside of it that consists of diagonal lines. when the plywood detail item is horizontal or vertical those diagonal lines read correctly. anytime i place the plywood detail item at an angle the diagonal drafting pattern doesnt rotate with the detail item. wondering if there is a way to correct this? meaning if i rotate the detail item 30 degree the drafting pattern within will also rotate. i am going to attach this detail item for your review
Tue, Oct 31, 2017 at 6:41:26 PM | ROTATE DRAFTING PATTERN WITHIN DETAIL ITEM
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hi,
Does this link help at all?https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Customize/files/GUID-02C84BD3-8CFC-40D4-8E21-A195A3C0BB2B-htm.html
Wed, Nov 1, 2017 at 3:57:32 PM | ROTATE DRAFTING PATTERN WITHIN DETAIL ITEM
archigrafix
5 Stars: 4 Votes
Thank you for the link.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Thu, Nov 2, 2017 at 8:03:01 AM | ROTATE DRAFTING PATTERN WITHIN DETAIL ITEM
BTW folks, the link posted is straight out of Revit's HELP and has been there for as many issues as I have Revit.  A simple search of "drafting pattern" brings up this section and many others.  If you do not take the time to read your help, you are missing oput on a lot of useful information.
I can't see the pattern on a subregion of toposurface. hence can't rotate it.
Sun, Aug 2, 2015 at 2:37:12 PM
OOTB LVL-Laminated Veneer Lumber-Section DETAIL ITEM fill region rotation (2017)
Wed, Sep 12, 2018 at 12:15:26 PM
batt insulation fill pattern (drafting)
Wed, Nov 11, 2020 at 6:01:17 AM
Rotate Model Fill Patterns [ 1 2 ]
Sat, Nov 28, 2009 at 5:21:54 PM
15
Cant rotate drafting style pattern?
Thu, Aug 18, 2011 at 11:08:52 AM
12
Page generation time: 0.6360
