Forums >> Revit Building >> Technical Support >> Stairs Issue - Fliping problem
Tue, Oct 31, 2017 at 5:49:50 AM | Stairs Issue - Fliping problem
lukaszmalec
Hi,
I have a problem with filiping stairs attached.
While flipping the upper run is deleted, however on the plan it exists.
Any suggestions?
Tue, Oct 31, 2017 at 6:00:41 AM | Stairs Issue - Fliping problem
lukaszmalec
I've failed to attach the 3d model, but here's the 2d outline of the stairs.
Do you have some tips to create them in the way shown?
I've used monolith stairs by sketch but it works only in the other way round than desired.
Tue, Oct 31, 2017 at 6:45:25 PM | Stairs Issue - Fliping problem
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
I can't seem to open the rar file. Have you looked at the stair in 3D to see if it is all there?. Sometimes the stair tool can be a bit glitchy and it is often quicker to remodel the stair from scratch than spend lots of time trying to figure out what it is doing.
Wed, Nov 1, 2017 at 3:51:49 PM | Stairs Issue - Fliping problem
archigrafix
5 Stars: 4 Votes
What about mirror or rotate?
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Stair Issue [ 1 2 ]
Mon, May 11, 2009 at 1:40:15 PM
17
Assembled Stairs - Joining stringers from one set to the landings of another
Thu, Mar 13, 2014 at 3:13:48 AM
Problem with U-shaped stairs
Tue, Jul 9, 2013 at 8:10:56 AM
Having problem in modeling stairs in REVIT
Sun, Nov 7, 2021 at 1:25:37 AM
My railings doesn't go with my stairs
Mon, Dec 2, 2013 at 11:45:03 AM
14
Page generation time: 2.1612
