Forums >> Revit Building >> Technical Support >> Paint material to stairs soffits
Mon, Oct 30, 2017 at 4:17:34 AM | Paint material to stairs soffits
Jules060
Trying to do a materials takeoff for stair soffits and cannot figure out how to apply a paint finish to the soffit surface.
Any help appreciated.
Tue, Oct 31, 2017 at 1:24:46 AM | Paint material to stairs soffits
Elnazer2
4 Stars: 5 Votes
i tried to paint a normal monolithic stair created in autodesk standard template and it worked smoothly check your process again , or upload the stair in here
Tue, Oct 31, 2017 at 6:50:59 PM | Paint material to stairs soffits
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
This is probably a silly question but were you using the Paint tool? ( See https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/RevitLT-Model/files/GUID-8BAA7C07-D174-4F02-AA81-239FD33BE363-htm.html )If so, did you pick the right material from your material library that will show a different finish to the stair material?Were you picking the stair soffit? To be sure try a 3D view and redo.
Paint Material Takeoff-Walls
Mon, Aug 11, 2008 at 11:56:32 AM
"Paint" and In-Place Component Material Bug?
Thu, Apr 14, 2016 at 2:47:43 PM
Do roof soffits really need to be scheduled?
Wed, Mar 10, 2010 at 5:57:08 AM
WALL CUT (openings) MATERIAL
Sat, Sep 28, 2013 at 10:56:04 AM
Material tags in painted wall faces Revit 2014
Sat, Oct 15, 2016 at 1:25:08 PM
Page generation time: 0.2474
